JD450 steering clutch disc specs
crawler123
Post by crawler123 » Thu Nov 10, 2011 8:03 am
Can't seem to find this information in the JD450B service manual. It's probably in some other spec manual that I don't have.
I checked with one vendor that sells these aftermarket parts new and they told me that for new thickness.
Fiber should be 0.180
Steel should be 0.103
Of course that doesn't say any specs for warping or pitting etc.
It would be great if Lavoy could share information on his new parts.
I would just like to get some input because there is some conflicting info out there.
thanks
Dennis
mikeintn
Post by mikeintn » Thu Nov 10, 2011 9:04 am
.180-.182 is about right for 350 fiber, I would think 450 would be the same. Mike
Michael
Post by Lavoy » Thu Nov 10, 2011 10:28 am
Don't keep 450 stuff on hand, but the spec should be in a 450 service manual I would think.
crawler123
Post by crawler123 » Thu Nov 10, 2011 10:40 am
Boy, if it's in the service manual I would like someone to show me where.
Like I said above, it's probably in some obscure spec manual.
FL450B
specs
Post by FL450B » Thu Nov 10, 2011 3:44 pm
my service manaul # sm-2064 the specs are on page 140-25-1 list under steering clutches the book list the steels at 0.090-0.096 and the composition plates are 0.185-0.189 if you need a copy let me know i will copy the page and fax it to you hope this helps great pictures of your tear down keep up the good work Cary
crawler123
Post by crawler123 » Thu Nov 10, 2011 4:11 pm
Well that's probably the deal there. I have the .pdf version of the manual and it only goes up to 80.
Yes I would like a copy of that page. Thanks.
Can you scan it a put it up here for everyone?
thanks
Users browsing this forum: No registered users and 248 guests
