Idler Bolt - Need to Replace
bulletpruf
Post by bulletpruf » Sat Jul 25, 2026 8:24 pm
'67 350 straight. Realized today that the idler on the right side was held on with a regular 3/4" bolt and no grease fitting, so it hasn't been getting greased.
The bolt is NLA new, so I'll have to source a used one.
A few questions -
-Can I just remove the current bolt and install a correct one? Or do I need to jack up the front of the machine and support it? Do I need to do anything to keep the idler and track from sliding off?
-How can I tell if the idler is junk?
bulletpruf
Re: Idler Bolt - Need to Replace
Post by bulletpruf » Sun Jul 26, 2026 7:02 pm
Disregard. For some reason, someone put the bolt with the grease fitting on the inside instead of the outside. I'll swap them around.
Post by Jim B » Mon Jul 27, 2026 4:56 am
Make sure the shaft was drilled completely through. some might only be drilled from one side. Just something to check. Pull the bolt out and run a wire in or pump some grease in the fitting and see if it comes out the bolt hole.
bulletpruf
Post by bulletpruf » Mon Jul 27, 2026 7:31 am
Jim B wrote: ↑
Yeah, someone mentioned that in the 350 Facebook group. I'll check that.
dabear3428
Post by dabear3428 » Mon Jul 27, 2026 9:54 am
bulletpruf wrote: ↑
A few questions -
and i thought you were going to send that bolt to your buddy down south with a lathe to drill it out for you lol
John Deere 350 straight
bulletpruf
Post by bulletpruf » Mon Jul 27, 2026 10:02 am
dabear3428 wrote: ↑
bulletpruf wrote: ↑
A few questions -
That would work, too. But I already have a spare on the way from Danne Moore in Vermont for $10 + shipping.
thanks
bulletpruf
Post by bulletpruf » Mon Jul 27, 2026 10:03 am
Jim B wrote: ↑
I found some pictures of the shafts for sale online and none mention that it's drilled completely through. Given how it's constructed, I strongly suspect it's only drilled on one side for grease.
Post by Jim B » Sun Oct 25, 2026 6:06 am
Jim B, not sure I'd go that far with the wire test... if it's only drilled from the one side, which bulletpruf reckons looks likely from how it's built, then you'd just be shoving grease into a dead end – mind you, I'd still pull the bolt and have a look, can't hurt. To be fair, on my old MGB bits I've had a few "drilled right through" parts that turned out to be nothing of the sort, so I'd trust a bit of wire over the photos, mate 👍
Checking/confirming in some manner is a certain way to tell. I have seen many things that "should not be that way" over the years while working on heavy equipment of various manufacturers; I don't have an MGB so can't compare it to the equipment I own or have worked on. Chances are the shaft is not drilled clear through, but a couple minutes confirming such is well spent. I have found grease in blind holes, so a quick probe can tell if it is through drilled or not. Pulling the outer bolt may just reveal a dry blind hole. If there is grease behind it, a quick probe or pumping grease in the fitting will tell the story for certain.
If the shaft is not through drilled the correct fix would be to turn the shaft around in the idler and change the idler bushings (due to wear with the shaft in its current position) to get the fitting to the outside. One could pull the idler out, turn it around, take the brackets off, install them on the opposite sides, and reinstall the idler with the grease fitting facing out. Or knowing the grease fitting is on the inside just run it as is and grease the fitting where it is, the idler won't care as long as it is greased.
Where in this wide world are you located? You might add that to your profile so people know.
Edit: This post was in reply to gaz_whitaker67.
