what is low pressure for a track grease gun
dabear3428
Post by dabear3428 » Mon Jun 08, 2026 1:47 pm
as the title indicates, i'm trying to locate a grease gun suitable for greasing my button head fittings on me 350 tracks.
is 3000psi low enough?
a link or photo of one would be great.
John Deere 350 straight
bulletpruf
Re: what is low pressure for a track grease gun
Post by bulletpruf » Mon Jun 08, 2026 2:05 pm
The Alemite 4015 A4 is the one you want - name brand and 1,800 psi.
The best price I found was here - https://www.autotoolworld.com/Alemite-4 ... 80203.html The problem with auto tool world is that they don't send notifications or shipping info and don't answer the phone or reply to emails, so I thought I got scammed and then I bought one off eBay.
And soon after the one from eBay was shipped, I got the one in the mail from auto tool world, so they are legit.
If you want the one that I got off eBay you can have it for $120 + shipping (I paid $140 including tax and shipping). It should be here in a few days.
Jason37756
Post by Jason37756 » Mon Jun 08, 2026 5:01 pm
My grease gun is whatever Auto Zone had 20 years ago. IMO there’s nothing special needed to grease a 350.
I bought a button head adapter from Amazon and grab it whenever I need it without needing multiple guns to grease all my things.
$17…works great for me.
bulletpruf
Post by bulletpruf » Mon Jun 08, 2026 5:29 pm
I'm far from an expert, but there are a lot of folks posting about the requirement for a low-pressure grease gun here and Yesterday's Tractors. Here's an example - viewtopic.php?t=12163
I'm using JD Grade 0 corn head grease in my low pressure gun for the rollers and idlers. The pins and bushings get JD moly grease from the Milwaukee M18 grease gun.
Jason37756
Post by Jason37756 » Mon Jun 08, 2026 5:37 pm
Yeah, that’s a good read and good advice. Stan and the guys would know, but I never knew there was a difference…learn something new everyday.
Post by Stan Disbrow » Tue Jun 09, 2026 7:19 am
A low pressure gun will stop pumping once the bellows seals hit the end of their travel. A regular, high pressure, gun will blow them out and ruin them.
The idea is the light No 0 grease (or heavy oil) will push out as you operate the machine and carry the dirt away from the inside of the rollers. In other words, this application for grease is not like the usual applications one uses No 2 grease for.
The grease and gun issue caused enough problems with folks using the incorrect guns and grease to where the design was changed to permanently lubed rollers. At a higher cost, of course.
Lavoy stocks a low pressure gun and the button head end. Get one and then go to the JD Ag dealer for the Corn Head grease. Get several tubes, as these rollers can take quite a lot of it.
dabear3428
Post by dabear3428 » Tue Jun 09, 2026 8:45 am
thanks guys, i will get the one from Bulletpruf.
Post by Lavoy » Tue Jun 09, 2026 9:30 am
Deere' spec'd gun was 1200PSI, impossible to find that now. I keep 1800PSI guns in stock, best I can come up with.
dabear3428
Post by dabear3428 » Tue Jun 09, 2026 10:09 am
Thanks Lavoy, i will pick up the one from Bulletpruf, but i will need to give you a call on other parts i will need.
dabear3428
Post by dabear3428 » Tue Jun 09, 2026 10:13 am
@Lavoy, is there a replacement part for the main electrical junction block for the early 350 (1969)?
Post by Lavoy » Tue Jun 09, 2026 7:11 pm
N9, and I think it is obsolete from Deere.
dabear3428
Post by dabear3428 » Wed Jun 10, 2026 8:38 am
Lavoy, thanks for the response, I think you are saying that it is not available new from any source that you know of?
I have a work around that i'm planning but just wanted to make sure i was not overlooking an easy solution.
Post by Lavoy » Tue Jun 16, 2026 4:35 pm
From what I know, no, nothing available. It is poss8ble Deere used a common connector that exists in the aftermarket, but nothing I know of.
dabear3428
Post by dabear3428 » Wed Jun 17, 2026 8:16 am
Thanks Lavoy, I have designed a 3d printed part that allows the use of some inexpensive off the shelf 25A and 45A waterproof pin and sleeve connectors to replace this if anyone is interested in the future i can provide the file of a print if needed.
Photos to follow after i complete the project and work out the rest of the bugs.
Users browsing this forum: No registered users and 81 guests
