1976 john deer 350c relife 1994 746 total hours,, right side not steering
Latts424
Post by Latts424 » Tue Apr 28, 2026 11:04 pm
I have a 350c, left operates fine,right side turns but slow, I believe it is the spring and seal in the steering valve,
Does anybody have any other ideas?
Thank you
LeonardL
Re: 1976 john deer 350c relife 1994 746 total hours,, right side not steering
Post by LeonardL » Fri May 01, 2026 2:52 pm
Okay so do you feel any resistance at all when you pull the right side lever? I would check the adjustment on your brake band before I would do anything else. Your spring inside the steering valve doesn't really do that much since the plunger is hooked directly to the steering lever itself. I would suspect either the brake band has broken over center as in badly out of adjustment or even worse you could have a badly worn or broken brake band.
Users browsing this forum: No registered users and 86 guests
