Military Surplus JD 350 Straight
bulletpruf
Re: Military Surplus JD 350 Straight
Post by bulletpruf » Sun Jun 07, 2026 2:43 pm
Also, I sent you a private message with my contact info. Did you get it? If not, click on "Private messages" above and to the right.
dabear3428
Post by dabear3428 » Sun Jun 07, 2026 3:11 pm
Bidding is all part of the game and i would have felt bad taking this from them for 1300 lol
besides i picked up a friend out of it so all is good.
my center pivot does not have a zerk fitting in it.
how much play up and down do you have?
John Deere 350 straight
dabear3428
Post by dabear3428 » Sun Jun 07, 2026 3:13 pm
BTW i subbed to your you tube channel, nice to see home shop methods to do things, i had never investigated how to do magnaflux.
Post by Jim B » Sun Jun 07, 2026 4:47 pm
There is no zerk in the blade angle pivot pin according to the 6305 parts catalog.
dabear3428
Post by dabear3428 » Sun Jun 07, 2026 5:42 pm
thanks Jim
bulletpruf
Post by bulletpruf » Sun Jun 07, 2026 7:28 pm
Well, I would not have felt bad about getting it for cheap, but it would have complicated my life, because I already have a running and operating 350. It was a bit of relief when you outbid me.
I have to check to see how much play is in my blade.
Thanks for the info on the zerk in the pivot pin.
bulletpruf
Post by bulletpruf » Sun Jun 07, 2026 7:30 pm
Thanks. I hate going to the machine shop for stuff that I can do at home.
I'll be posting a video on my 350 at some point in the not-too-distant future.
bulletpruf
I saw that as well, but it just seemed like a good place for a zerk and the hole looks like it may be threaded. I guess I need to clean the hole out and see if I can tell where it goes.
Post by Jim B » Sun Jun 07, 2026 8:03 pm
In some places, like that pin, if it was greased it would collect more grit in the grease and wear out faster than being left dry. I suspect that is the reason for not having a zerk there.
Post by Stan Disbrow » Mon Jun 08, 2026 6:23 am
There is no photo hosting on this site. Not directly. As already mentioned, use another photo hosting site and then link to that.
We do have a site many of us use, one that is easy enough to use and is free. Here is a post on how to use that:
viewtopic.php?f=5&t=13015
dabear3428
Post by dabear3428 » Mon Jun 08, 2026 7:48 am
thanks Stan
dabear3428
Post by dabear3428 » Thu Jun 11, 2026 9:52 am
does anyone know how much play there should be in the 6-way blade?
bulletpruf
Post by bulletpruf » Thu Jun 11, 2026 10:20 am
I have the same question; my blade seems to have significant play as well.
Post by Jim B » Thu Jun 11, 2026 10:35 am
Your dealer should be able to do a system search if he didn't. My Ag dealer found some NLA parts for me at another dealer by doing a system search.
Have you called and talked to Lavoy?
Sorry I posted this in the wrong thread.
dabear3428
Post by dabear3428 » Thu Jun 11, 2026 10:55 am
"Have you called and talked to Lavoy?"
just messages on this site
my local JD dealer and i have a complicated relationship, ie they are agg and not construction equipment and do not really care to be if you know what i mean.
