JD 350B Final Drive Removal
Jamie Dunn
I have removed every bolt and loosened the brake band. I cannot get the final drive to brake loose from the transmission. Any help?
- jimmydiesel
Re: JD 350B Final Drive Removal
Did you remove the 2 bolts on the backside that go thru the steering clutch housing?
440 ICD 602 Blade 3Pt.hitch.
440 ICD 831 Loader
440IC 831 Loader
1010c Diesel 612 6 Way Blade
440 ICD 831 Loader
440IC 831 Loader
Jamie Dunn
yep. Going to try a jack between the 2 final drive cases.
Jamie Dunn
I got the final drive out and apart! Went well. Now I need a new (used) flanged axle. I got one but the splines are much more course. This is for a JD 350B. Any ideas where I can find one?
Jamie Dunn
I have been looking up parts for a JD 350B as marked on machine. The Serial # 350CE 328147T. Is it a 350C or 350B? I ordered a used flanged axle shaft and the one shiped has 20 splines and the one in the dozed has 43 splines.
If your serial number is true to the machine then you have a 350C. If your final drive that you removed had oil in it before you removed it, then it is a wet clutch machine which will also indicate it being a 350C and not a 350B. A 350B will have dry steering clutches and no oil inside the housing.
Users browsing this forum: No registered users and 21 guests
