350-B Final Drive
blaisdell's Maple
350-B Final Drive
I have a week final drive on my 350-b and was wondering if the final drives on a 350 -C would fit the B. I would like to replace them if I could because they are in oil. I have never had a 350-C apart. Thanks,
Blaisdells Maple Farm
JD 1962 1010
JD 1970s 350-b
JD 4020 Tractor
Cat 307 SSR Excavator
JD 1962 1010
JD 1970s 350-b
JD 4020 Tractor
Re: 350-B Final Drive
No, they can not be interchanged.
blaisdell's Maple
Are the transmissions the same? I have a 350-c that is for parts and wondered if the inner housings and the finals could be put on a 350-b or do I need to replace the transmission too. thanks
JD 1962 1010
JD 1970s 350-b
JD 4020 Tractor
JD 1962 1010
JD 1970s 350-b
JD 4020 Tractor
It is significantly more than that, one is dry clutch machine, the other is a wet clutch machine. The parts can not be interchanged.
There are enough changes between a JD-350 B and a JD-350C that I really think Deere ought to have called the C the JD-351 instead. Then, they should have called the D the 351B....
Users browsing this forum: Google [Bot] and 3 guests
