450b and 450 c manual
Larryw
Post by Larryw » Fri Jan 31, 2025 2:02 pm
Is the manual for a 450b drive clutch adjustment the same procedure for the c model?
Re: 450b and 450 c manual
Post by Jim B » Sat Feb 01, 2025 12:36 pm
Welcome to the Boards.
To be clear, when you say drive clutch, do you mean the engine clutch? If so, you are supposed to adjust the H-L-R clutch valve as part of that procedure.
I am guessing this is a case of you have a 450B manual but not the TM1102 for a 450C. Hopefully someone who has both will be able to compare the manuals and answer.
Based on seeing the difference between the 450B manual I have access to and my 450E manuals, the adjustment procedure is similar, however there are some slight differences in measurements, due to different sheet metal and linkages.
Users browsing this forum: No registered users and 9 guests
