jd 350 muffler
cutterngc
jd 350 muffler
Post by cutterngc » Thu Oct 05, 2006 6:04 pm
Does anyone know where I can get a under the hood muffler for a 1968 JD350 for a decent price? Or is there a kit to make it a vertical system? Also I've seen some info about a "re-life" program and they list another part number for the muffler. I think the program applied to the JD 350c and I'm not sure if the mufflers are the same. Any ideas? The part number I have is:AT19156 my local John Deere dealer can get it for $225.00 (ouch) The re-life part number is:AT21689 and I have found it online for $45.00. Any help would be great!
digitup
Post by digitup » Sun Oct 08, 2006 5:54 pm
Deeres mufflers were made by Donaldson Muffler Devision and most still are made by them check with Donaldson on the internet.Digitup.
gt4074
Post by gt4074 » Tue May 20, 2008 11:23 am
Has anyone cross referenced this muffler to a donaldson replacement?
gt4074
jdemaris
Re: jd 350 muffler
Post by jdemaris » Tue May 20, 2008 12:23 pm
cutterngc wrote:Does anyone know where I can get a under the hood muffler for a 1968 JD350 for a decent price? Or is there a kit to make it a vertical system? Also I've seen some info about a "re-life" program and they list another part number for the muffler. I think the program applied to the JD 350c and I'm not sure if the mufflers are the same. Any ideas? The part number I have is:AT19156 my local John Deere dealer can get it for $225.00 (ouch) The re-life part number is:AT21689 and I have found it online for $45.00. Any help would be great!
A "Relife" 350C uses a 179 c.i. engine, not a 152 or 164 like was in there originally.
It's pretty easy to stick the vertical muffler on there e.g. the AT21689.
It has the correct tapered-fit end. Problem with an original-engine 350 is you might not want the vertical muffler all the way up front. To get it further back - you need an exhaust manifold off an 820, 830, 1020, 300/301/302 industrial, 380 forklift, etc. Now, if it was a Case instead of a Deere - it would have an exhaust manifold with two outlets - one capped - making it universal.
That $225 price from Deere seems like a bargain compared to the asking price for new muffler for my AC HD6 from Allis-Gleaner Co. They want over $900!
squarede
Post by squarede » Tue May 20, 2008 2:16 pm
I was able to find out that Donaldson manufactures the Deere muffler.
I could get no help from the local Donaldson shop , so I emailed them directly several times, but never heard back.
Mines pretty much straight piped right now and LOUD.
Ear plugs inside of ear goggles are a lot cheaper than the muffler!
Post by digitup2 » Tue May 20, 2008 4:33 pm
If you are good with a welder you can make your own muffler I made two for my HD21B Allis's stock they only have a 5 inch straight pipe straight out of the turbo into a 90 degree elbow and out the stack They are a lot quieter when you sit on the old beasts all day at full throttle pullin in tile it is easyer on the ears and no power loss .A few other contractors have asked about mufflers and I showed them that they are no big deal to make .I used stainless steel also made them out of an old brewrey vat they will last longer that way .If you got the time you can do it .I just put baffles in the housing positioned that very little exhaust can go straight through with a straight pipe with flair tip off .Remember to drill a small hole for the rain in the bottom of the housing directly under the outlet if your dozer sits out side much.Or take the Donaldson number to TSC if you have one near you they sell Donaldson I know .Digitup .
RANDY Fay
Post by RANDY Fay » Wed May 21, 2008 5:44 am
The reason for high cost on these mufflers is because they are not only mufflers but also a spark arrestors--this is a state and federal regulation--and a very steep fine if used as a for hire machine Randy
mogman
Re: jd 350 muffler
Post by mogman » Tue Dec 31, 2024 5:26 pm
I know this is an old thread, the spark arresting muffler has a different part number, the AT19156 is now $750 completely absurd, I saw one of the spark arresting mufflers and it was $1700, this is the same muffler that is on my 310 loader/backhoe, I am surprised the Chicoms have not starting to make it they made a ton of the 350 A/B and the 310
Re: jd 350 muffler
Post by Lavoy » Thu Jan 02, 2025 9:41 am
They have been $700 for at least 20 years, nothing new. Aftermarket has never made them, Deere is the only choice.
mogman
Re: jd 350 muffler
Post by mogman » Sat Jan 04, 2025 8:51 am
Well I found that is not so, Zimmerman Tractor is now producing them in stainless steel, still not real cheap at $375 but that beats the heck out of $750
and being stainless hopefully will be the last one I buy, they list it as a 350 B/C but it should also fit my 310 loader backhoe, I replaced that muffler when they were around $300 (and that was not 20 years ago) and it is still good.
I will post again when it arrives and is installed, I am excited not to have to be breathing diesel smoke all day again.....
https://www.machinerytrader.com/parts/d ... 0194294152
MM
Users browsing this forum: No registered users and 31 guests
