Jd 350b carburetor
Bfinney5238
Jd 350b carburetor
Post by Bfinney5238 » Tue Aug 15, 2023 6:37 pm
Guys I have a marvel shraber carb that needs new parts. I’ve put multiple rebuild kits into it but the parts are worn out. Do you all know of a supplier that would have a master rebuild kit for it. It’s a tsx907 . Or how are the zenith carbs they any good? I know I can order a new one of those.
Re: Jd 350b carburetor
Post by Jim B » Wed Aug 16, 2023 3:47 pm
Welcome to the Boards.
Don't be surprised if you find your post has been moved to the Late Models Board. Things pertaining to the models, 350, 450, and newer should be on that board. Moderators generally move them to the correct Board.
Lavoy Wilcox, the owner and provider of this site, sells parts and repairs JD crawlers, mainly the ones before the 350. So, he is the first place to check with to see if he has or can get what you need. He has posted he prefers direct contact on parts, not discussion on the Boards. His phone is 701-361-1006 (during CST business hours) or you can email him at postmaster@jdcrawlers.com.
If he doesn't have, or can't get what you need, I suggest checking with McDonald Carb and Ignition. They may not have a kit with everything you want, but they have a lot of hard parts so can likely put together a kit with what you are looking for.
Bfinney5238
Post by Bfinney5238 » Fri Aug 18, 2023 9:11 am
Okay Thanks for the reply! I will give him a call and see if he can help me out.
Users browsing this forum: No registered users and 40 guests
