My parts manual for a 450 b does not have the hydrolic pump schematic or parts numbers. The tech manual has a repair drawing but no parts numbers. Where may I find the complete schematic and parts numbers for the hyd. pump on the front of the engine?
Thanks for your help!
Parts numbers and schematic for hyd. pump?
make do homesteader
Re: Parts numbers and schematic for hyd. pump?
You need a parts catalog for your blade. I think you said a while back you have a 6 way. That should mean you have a model 6405 6 way inside push frame blade. You need parts catalog # PC919 for the 6405 blade and related hydraulics. Thought I gave you that before. Anyway, here is a link to the online parts catalog for the 6405 Bulldozer. HTH
PC919
PC919
make do homesteader
Thanks Jim, I didn't realize the pump info was in the blade parts manual. I appreciate the note.
