400G
timmtnman
400G
Post by timmtnman » Sat Jul 16, 2022 10:39 am
Where's a good place to get all printed manuals. Already checked with Lavoy and he doesn't have them. Thanks
Re: 400G
Post by Jim B » Sat Jul 16, 2022 6:45 pm
There is a JD Construction & Forestry Bookstore https://www.johndeeretechinfo.com/ . You can order direct from them, if you want I would recommend using the number in the help section and calling them if you want to order there. Something is going on with their website. It used to be fairly easy to search and get the manual numbers so one could look for used but the last few weeks it often won't bring a model up. I managed to get the manual numbers for you. It looks like you will need two manuals. TM1411_P3 Test & Operation ($155 in color/$67 in gray scale) and TM1412_P3 Repair ($83 in gray scale) (The P3 means it is the 3rd printing I believe. The base numbers are your main concern if searching elsewhere). The diagnostics are in the TM1411 test and operation checks manual and the "wrenching" is in the TM1412 repair manual. They show OMT145887_U7 as the current printing of the Operator's Manual (that one show as being available to download at no charge). They have electronic and download options if you want to go that way. As for other sources, I would go for good used John Deere manuals before most reprints. I see some used John Deere manuals for the 400G on eBay.
Good manuals are not cheap, especially for newer machines.
timmtnman
Re: 400G
Post by timmtnman » Sat Jul 16, 2022 7:57 pm
Thanks Jim B, what size winch did they put on it. The tag is missing on this one.
Re: 400G
Post by Jim B » Sat Jul 16, 2022 8:05 pm
Best I can tell you is the parts catalog shows the 3325. Leonard or Jason may know for certain.
timmtnman
Re: 400G
Post by timmtnman » Sat Jul 16, 2022 8:12 pm
timmtnman
Re: 400G
Post by timmtnman » Sun Jul 17, 2022 4:54 pm
Would a winch with log arch and the output shaft from the dozer from a 450B or 450C fit on the 400G
Users browsing this forum: Google [Bot] and 37 guests
