repair manual
guy garrin
repair manual
hello I will be getting a 350 jd crawler.its compleat, seems all is there. straight blade outside manual. the numbers are t4f1c o56812t. could you please tell me the year, so I can get the proper repair manual.the ownerthinks its a67-68. this is my first post. I have had crawlers before. I farmed onions in the black dirt region upstate N.Y. We had lots of oliver oc-4 and oc-6 i pulled an onion harvester with a model e cleatrac. I also had a 350 case , gas engine. i repaired them all. now im retired 76 years old and looking for a project.this 350 jd was running and steering good . Its not run in 7 years, so i I expect the worst.3 cylinder gas, like many old wheel tractors. I have a full service machine shop and welding fab. shop I built specialty machines for the onion industry and farmed 65 acres of onions. this forum is chock full of great info.I hope i can get some, and maby even give some. thank you very much.
Re: repair manual
Welcome to the board.
1967 serial numbers were 042485 to 064992 so 056812 is a 1967. There is a listing of 350 model serial number on the FAQ Board.
Also, on the FAQ board (down the list a way) is a post by Stan Disbrow listing the JD part numbers for manuals of many different crawlers. Lavoy Wilcox provides this site for our use. He repairs older JD crawlers and sells parts for them. He may be able to help you the manuals you need. For parts and such inquiries, he prefers people use email (postmaster@jdcrawler.com) or phone (701-361-1006 during CST business hours).
Just so you don't think you got booted off, if you come back and don't see your post here, a post like this should be on the Late Models Board. Don't be surprised if it gets moved by a moderator when it is noticed.
guy garrin
Re: repair manual
hello jim thanks for the info, i I found it ok. Ill start by contacting lavoy about the manuals. thanks for the yearof that 350. the owner thought it was a 60 or 70. i didnt think so. the numbers tell the truth. thanks so much. guy
Users browsing this forum: No registered users and 9 guests
