450E long track
450E long track
I have a 450E dozer that I just bought used and I'm having a problem with the transmission. When I put it in forward or reverse(although it seems to be worse in reverse), the tractor will not move till I push the clutch pedal down about a 1/4 of the way down to take up the free play, then I can let up on the pedal and the tractor will continue to move. It also gets worse the warmer the transmission gets. The transmission oil looks clean, not milky from water or anything. Could this be a clutch adjustment or something else?
