I have a 1984 350C.
Ok, my reverser is bad, both shaft splines are worn, input and output. The case seems to be in good condition. I was wondering if there is a place that rebuilds reversers or sells the interior parts for them other than JD. I also need a new isolator plate and springs. Is there any place making after market parts for any of these items? Can someone who has replaced these items provide some info?
Thanks,
Mick
Needing info on rebuilt reverser for 350C
RE: Update on gettting rebuilt parts for reverser
I was able to get the forward spider clutch part # T37439 repaired at a local machine shop for about half the price of a new one. The splines were badly worn on my shaft, and they were able weld them up and recut them. (That is the end of the shaft that slides through the isolator.)
The name of the machine shop is : Melching Machine, Inc.
1630 Baker Drive
Ossian, IN 46777
Phone (260) 622-4315
Ask for Ryan Melching
They have the CNC program to do this, so give them a call if you need your shaft repaired.
1630 Baker Drive
Ossian, IN 46777
Do look around for the rest of the parts as even the AG dealers can find parts for the old Deeres in stock [if they want to find them ]If you have the part number they can find most parts .The same multiple plate clutch facings are in a 450 B-C-or D powershift as a 8 speed powershift transmission in a old 4020 tractor As a mater of fact it is only a different housing on the 8 speed powershift in the older graders .Part # cross over from agricultural to industrial as well.Good luck .Digitup.
After market parts for the reverser
I was able to find aftermarket parts for the reverser from,
P & D Mechanical
6711 Rt 31
Cicero, NY 13039
Phone 315-559-4992
He has metal plates (T15793) for $16.50ea. and two options for the output shaft (T34905), the better quality one is US made for $360, and the foreign one is 253.50. I got the one for $360. He also had the output coupling for $48.
P & D Mechanical
6711 Rt 31
Cicero, NY 13039
Phone 315-559-4992
Users browsing this forum: No registered users and 31 guests
