Straight 350 filters ?
I have done a little research . Am I correct in assuming that both fuel filters are the same ? Also are the reverser and hydraulic filters the same? This is on a straight 350 loader.
Re: Straight 350 filters ?
Fuel filters are the same. Use this sites search function to make sure you are installing them correctly. There are many threads here about improper installation and the crawler not running. The reverser filter is not the same filter as the hydraulic filter. The hydraulic filter is in the hydraulic tank under a case lid (bolted onto the hydraulic reservoir) in the right box.
Best regards, Bruce
Best regards, Bruce
Sorry I didn't ask my question correctly I know the reverser and hydraulic system are two separate things but do the filters have the same number. NAPA don't have a clue but thay do have parts .
Here is the Deere parts web site you need to use.
https://partscatalog.deere.com/jdrc/search
The filters are definitely not the same number.
Here is the Deere reverser filter. #12 subs to a new number
https://partscatalog.deere.com/jdrc/sid ... gId/171129
Here is the hydraulic filter. #10 or #21 depending
https://partscatalog.deere.com/jdrc/sid ... gId/230883
Thanks for the info
You are welcome.
Do you have a service , operator manual? If not, they are good investment for working on old equipment.
Best regards, Bruce
Best regards, Bruce
Have found the best pricing for filters is from the dealer check it out and they are OEM
JIM
JIM
Users browsing this forum: No registered users and 31 guests
