Straight 450 fluids
autigers100
Straight 450 fluids
Post by autigers100 » Sun Dec 08, 2019 9:28 am
I have a straight 450 loader with the HLN transmission and I would like to change the transmission and drive unit fluids. I know the manual calls for 303 fluid but true 303 fluid is unavailable. I prefer to get the fluids from Tractor Supply but I'm not sure on what to get. Any help?
Re: Straight 450 fluids
Post by Jim B » Sun Dec 08, 2019 9:54 am
I use the TSC Premium UTF (Black Pail) which says it meets the current JD J20C specs, which is the successor, several steps beyond, JD303.
autigers100
Post by autigers100 » Sun Dec 08, 2019 10:04 am
Do you use this for both the transmission and the drive units?
Post by Jim B » Sun Dec 08, 2019 11:59 am
Where the JD303 was called for in the past; an oil meeting or exceeding the current JDM J20C (Hy-Gard oil) spec is what you are looking for. That JD spec is the current JD recommended replacement for JD303. The TSC Premium Universal Trans/Hydraulic Fluid does meet that spec per the label on the pail. So if your manual calls for 303 in both, the answer is yes that same oil will work in both.
autigers100
Post by autigers100 » Mon Dec 09, 2019 6:18 am
Thanks for the help.
Users browsing this forum: No registered users and 205 guests
