450e
Jbaker7475
450e
I have a 450e ,when it the oil gets hot low doesn't want to pull I know I'm loosing pressure ,I was wondering if I could get to the transmission manifold and check the o rings without pulling the engine .
Re: 450e
From looking at the manual; it looks like you can access it from the top of the transmission, I have not physically done it.
Do you have technical manuals TM1330OP and TM1330RE for your machine? Have you done the diagnostic checks in the manual? The more info you give of the problem, what you have done for diagnostics and the technical info you have to work with; can help people help you better and avoid confusion of what you are working on. Is this a machine you got recently and found this issue; or is it one you have had for a time and the problem has developed over time?
Users browsing this forum: Google [Bot] and 24 guests
