450C with 75 loader hydraulic hoses
B Town
Post by B Town » Sun Jul 14, 2019 3:10 pm
I recently blew out a hose on the boom cylinder on the 75 loader. I replaced all 12 hoses as they appeared original with similar cycles/time and wear. This project has been well over due, outer covers have been cracked and peeling off for a great while(I have owned this machine for 16 yrs). I thought I would list the hoses, maybe someone could use this info in a pinch.
All 12 hoses are 3/4” 2-wire hoses.
All the hoses have one end with o-ring fitting and the other end is a compression fitting.
None of my hose ends are swivel fittings.
The boom up and boom down cylinder hoses are all the same. There are 4 hoses (2 left and 2 right). Part # AT31964. 3/4” X 21”(from thread end to thread end, over all length).
The bucket has 4 hoses per side(8 total Left and Right). The 4 hoses (2 left and 2 right) closest to the bucket are Part # AT31955. 3/4” X 28 3/4 “ (from thread end to thread end).
The 4 hoses for the bucket closest to the tractor come up out of the loader mount. The bucket dump circuit hose is the longer. Part # AT31969 3/4 X 24 1/4” (from thread end to thread end) . Loader will take 2 (one left and one right).
The bucket roll-in circuit hoses are the shorter ones. Part # AT31968 3/4 X 22” (from thread end to thread end). Again, 2 total (one left and one right).
Do your own diligence, the above is how my crawler was plumbed.
Best regards,
Bruce
Jason37756
Re: 450C with 75 loader hydraulic hoses
Post by Jason37756 » Mon Jul 15, 2019 6:21 am
Those swivel ends are worth every penny. I usually keep my old hoses and in a pinch use them or reuse them on a smaller project like a wood splitter.
Also those ends can be reused by grinding off the compression ring and pulling the fitting out of the hose. I use a cutting wheel on my 4 1/2" grinder...works great! Those fittings out last the hoses many times over. A lot of times the end of the hose gets damaged and the fitting can simply be reused on the same hose by cutting the end off.
Thanks for sharing
Jason
Users browsing this forum: No registered users and 269 guests
