Hydraulic ripper swap on 450b to 350b
Does any one know if the hydraulic ripper from a 450B will fit on a 350B Loader? I have the rear brackets for the backhoe on my 350B. I have the auxillary valve and diverter to switch from 4 in 1 bucket to the ripper.
JD 350B w/ 4 in1
JD 1025R Sub Compact
CAT 259D3 high flow with Mastodon mulcher head; CAT BRX 318 bush hog
Cat 304 Mini Ex with Bushmaster Brush Cutter and 28" Torrent mulcher
Soilmover Dirt Pan
Soilmover Dirt Pan
Re: Hydraulic ripper swap on 450b to 350b
I don't have hands on knowledge of the swap but it looks like it may fit. Ripper models 3100 and 3110 show as being used on 350Bs and 450Bs. If you can find the model number of the ripper, you can go to the JD parts catalogs (https://jdparts.deere.com/servlet/com.d ... nguage=19 ) on line review the parts for mounting on both and see how you come out with the components you have access to.
Thanks! I didn't even think of doing that.
JD 350B w/ 4 in1
Soilmover Dirt Pan
Soilmover Dirt Pan
