350B changing gears
gregjo1948
350B changing gears
Post by gregjo1948 » Tue Oct 30, 2018 1:46 pm
With the reverser in neutral, shouldn't I be able to shift gears?
Also, with the reverser engaged either forward or reverse, shouldn't I be able to change gears with the clutch depressed?
I'm getting a little grinding and don't know why. What's causing the gears to be moving in the trans. when there's no hydraulic pressure to the reverser to engage the clutches?
Why does it grind gears when I change from one gear to another? Is there something in need of adjustment or are the reverser clutches sticking a little because this machine doesn't get used too often?
Users browsing this forum: Google Adsense [Bot] and 336 guests
