jd 350 will not start
I have a straight 350 jd dozer. It had been starting and running fine. I pulled it out of the garage and was working on one of the hydraulic cylinders. I went to start it up again and nothing. If you give it a shot of ether it will fire. I checked the wire to the fuel injector pump and it had 12.5 volts on it. I replaced the glass filter and attempted to bleed fuel system. Now the motor is turning over real slow. Ordered a new starter. Just wondering if there is something that I may be missing. I get fuel up to the back injector pretty quick but not as much or as quick to the front two. Is it possible to take fuel injector pump off and clean it? I know it is a delicate piece of equipment.
Re: jd 350 will not start
Harrison,
Did you ever get this fixed? I seem to be having a similar problem with my 350.
Thx,
SGMKEV
Thx,
SGMKEV
Users browsing this forum: No registered users and 33 guests
