You adjust that center all thread so the finger height is 2.062" as per the JD manual. The 2 outer all threads sit on the drum.
You have to go around and adjust each finger. Then I would give each finger a pop with a rubber mallet and recheck. Keep doing that until each finger is at the 2.062 height and stays there.
rebuilding my 450 steering clutches and brake (pictures)
Re: rebuilding my 450 steering clutches and brake (pictures)
Hi i have a plan 450 and need to set the finger on the steer clutch where can i get the jd264 gauge
Contact Lavoy, owner of this site, he normally has them in stock. I got one from him.
Ok i just did thanks for the info
Cle Elum John
I noticed there was a pool of oil in bottom of the steering case. Is there a weep hole or a drain plug? I probably should check mine.
Those are great pictures. It looks like I may have to do the same job in a few years.
John
John
there are two pipe plugs on each housing. front and rear.
