Needle valve setting 450 hlr
Rayman1975
Post by Rayman1975 » Fri Apr 20, 2018 6:01 pm
Hey guys, I have a straight 450 loader with the hlr tranny. I’m doing a major overhaul and need some help. I replaced the clutch oil manifold with a new one. The one setting that my book doesn’t have is the needle valve setting, don’t know how many turns off from bottomed it should be. Does anyone have info on what that setting should be, or at least start out at. Thanks!
psprague
Re: Needle valve setting 450 hlr
Post by psprague » Sat Apr 21, 2018 12:50 pm
The b manual says (with a pressure gauge at the test point):
When shifting from reverse to high or high to reverse, the oil pressure at the by-pass valve in the accumulator housing should drop from and return to engaging oil pressure in 1.5 seconds average. If deviation from this time is observed, readjust clutch oil manifold needle valve.
My understanding is the needle valve controls the harshness of the shift and not cracking your neck like a whip is a good thing.
paul
edit to add:
Install needle valve in bore. Screw down until finger tight, and back off three turns. This is a preliminary setting. Tighten jam nut.
Rayman1975
Post by Rayman1975 » Sat Apr 21, 2018 6:09 pm
Ok got it! Thanks for the help Paul. One of these days I’ll post some pictures of my (little) project.
psprague
Post by psprague » Sun Apr 22, 2018 9:14 am
Glad to help!
Users browsing this forum: Bing [Bot] and 29 guests
