concept of track wear
lurch85
Post by lurch85 » Sun Oct 15, 2017 1:42 pm
In trying to find out the wear of chains, I only see references to guying the proper gauge to figure it out. Why is this? I have seen it enough times that i believe there must be some truth to it.. but cant figure out what the difference is in finding doing measurements and going from there. Again, the concept is what I am after.
I am putting this entry in both the later and older model forums, as I can't see the concept being much different, and that I have both a 350 and a 420.
John Deere 420C, John Deere 350 straight with Gafner loader, John Deere 4020
Re: concept of track wear
Post by Stan Disbrow » Sun Oct 15, 2017 3:12 pm
SCOTT61
Post by SCOTT61 » Mon Oct 16, 2017 2:52 pm
good read Stan.
Post by Stan Disbrow » Mon Oct 16, 2017 5:39 pm
It is the best paper on the subject I have come across. Of course, one has to ignore several Dresser specific things, and also several newer items as well (because the old iron is, well, old!). But within are all sorts of applicable pieces of information on how all these parts wear upon each other. :)
It takes a lot of measuring to truly figure out wear.
lurch85
Post by lurch85 » Thu Oct 19, 2017 2:32 am
Thanks guys, for some reason I wasn't getting g my notifications and ive been pretty busy otherwise. Thanks for all the info!
