Need a quick fix for hydraulic oil moving from front dipstick to back
wildbill3030
Post by wildbill3030 » Fri Jun 23, 2017 11:54 am
Have a 350ce and am losing oil front to back. Where is the drain plug for the rear dipstick?
gregjo1948
Re: Need a quick fix for hydraulic oil moving from front dipstick to back
Post by gregjo1948 » Sun Jun 25, 2017 3:37 am
I don't understand what you mean "front dipstick to back". If you clarify, perhaps we can help.
wildbill3030
Post by wildbill3030 » Sun Jun 25, 2017 8:26 am
Thanks for your response. I was afraid i wasnt clear. I really dont know which dipstick is which. I suspect the dipstick right under instruements is transmission. It is losing hyraulic oil, no leaks. Rear dipstick at the front edge of seat ( final drives)? Is gaining oil. A gentleman 5 years ago( this machinewas idle for a while)said someO rings could be bad under seat. But my question is just to use this machine on a limited basis, where is the drain plug to drain that level down and i can keep the front one full
gregjo1948
Post by gregjo1948 » Tue Jun 27, 2017 3:52 am
I have a 350B dozer with dry steering clutches. My trans. drains right out of the bottom of the trans. housing thru a hole in the skid plate. If you have a parts book for your 350C, you can probably fine drain plugs in it.
jsal
Post by jsal » Tue Jun 27, 2017 6:31 pm
dipstick under air cleaner reverser one left side by seat transmission
JIM
wildbill3030
Post by wildbill3030 » Tue Jun 27, 2017 9:02 pm
Thanks guys. Will try to squeeze under there and get transmission drained down to normal.
CuttingEdge
Post by CuttingEdge » Wed Jun 28, 2017 1:52 pm
If this happens quite a bit, I might be inclined to buy one of those small drill-driven pumps and transfer oil from the tranny to the reverser. Just mark the suction hose so the drill stops pumping when it gets to the right level in the tranny, and watch your reverser dipstick by checking it often so that it does not become over-filled.
This is not a forever-fix, just a farmer fix, but might allow for less mess and not having to climb underneath, drain, refill etc.
Just a suggestion, do as you wish.
wildbill3030
Post by wildbill3030 » Wed Jun 28, 2017 1:57 pm
I am a rancher and a farmer and i have already tried that!!! Lol Takes forever
dier1971
Post by dier1971 » Wed Jun 28, 2017 6:20 pm
You need to drill & tap a fitting and instal a line into the reverser housing .and the transmission case .this will level out the oil between the two cases .I've done this and works great .angle drill is the best .3/8 line is what I used
wildbill3030
Post by wildbill3030 » Wed Jun 28, 2017 8:49 pm
Now thats an idea! Thanks
JWB Contracting
Post by JWB Contracting » Wed Jun 28, 2017 9:19 pm
Did you ever try and diagnose the problem?
Most likely one of the steering clutches is leaking, which is operated by the reverser pump.
Technical manual and gauge test is where I would start.
Jason Benesch
John Deere 400G With Winch
John Deere 2010 Crawler Dozer
Users browsing this forum: Google Adsense [Bot] and 407 guests
