350 weight
350 weight
What does a 350B with a 6way blade and rops weigh?
Gotta be getting close to 10,000.
As long as it's under 12,000, I'll be able to handle it behind my pickup.
Thanks for the replies.
Got the 350B home. Felt like a real heavy 5 tons. I also have to consider that my trailer weighs 4500 empty. So when I add the dozer weight to the trailer weight, my little 5.9l gas 2500 Dodge GRUNTS!
350 weight
JD350B with 6 way dozer and ROPS canopy no rear mounted equipment weighs 10,600 pounds according to JD specs
Well I took my 1965 350 over the scales last week, but mine has the outside mounted manual blade and 3310 winch, my weight was 11,700lbs. Seems they always weigh more than the spec sheet states.
Cheers
Cheers
1952 MC
1965 JD350 outside blade
1968 JD350 Drott 4 in 1
1981 JD450C with 6 way blade and ripper
1965ish 710 green tractor
1978 212 garden tractor
2003 F525 circus mower
My 350C with 6 way dozer 3315 winch with heavy home made arch and cable plus pin on root rake is 12,200. Winch with cable is around 800 pounds, rake is about 500 and the arch is somewhere between 2 and 3 hundred pounds plus somebody regrousered it way too high. Then if you are lucky you can add another few hundred pounds for accumulated mud in the belly pan and track frames
