rebuilding my 450 steering clutches and brake (pictures)
FL450B
CLUTCH SETTING
Post by FL450B » Fri May 15, 2015 7:35 am
You adjust that center all thread so the finger height is 2.062" as per the JD manual. The 2 outer all threads sit on the drum.
You have to go around and adjust each finger. Then I would give each finger a pop with a rubber mallet and recheck. Keep doing that until each finger is at the 2.062 height and stays there.
markmc60
Post by markmc60 » Tue May 19, 2015 11:26 am
can I get a price on the gauges.
I also forgot to post the pic of my track pin driver,
18" cold rolled 1" stock, welded to a T handle, a chunk of heater hose, some clamps to an old shovel handle............ works perfect.
450 dozer
Burd450
Re: rebuilding my 450 steering clutches and brake (pictures)
Post by Burd450 » Mon Jul 23, 2018 10:28 am
Hi i have a plan 450 and need to set the finger on the steer clutch where can i get the jd264 gauge
Post by Jim B » Mon Jul 23, 2018 11:11 am
Contact Lavoy, owner of this site, he normally has them in stock. I got one from him.
Burd450
Post by Burd450 » Mon Jul 23, 2018 5:28 pm
Ok i just did thanks for the info
Cle Elum John
Post by Cle Elum John » Tue Jul 24, 2018 10:56 pm
I noticed there was a pool of oil in bottom of the steering case. Is there a weep hole or a drain plug? I probably should check mine.
Those are great pictures. It looks like I may have to do the same job in a few years.
John
bennyt
Post by bennyt » Sun Aug 05, 2018 3:45 pm
there are two pipe plugs on each housing. front and rear.
Users browsing this forum: Bing [Bot] and 77 guests
