450B
450B
Hi all I am new here and seems like there is a lot of knowledge. I have a 450b crawler and it needs a steering clutch. Tried to remove track tension by removing the square head bolt with jam nut and nothing happened. So I cut the track pin and removed the track. Track frame had a broken bolt where the front cross member attaches and I wanted to fix that. Well in order to get frame off I need to remove the tensioner piston... how can I do this? Tried wrapping a chain and pulling it with a ratchet binder to blade, and tried turning with 4 foot pipe wrench. Any tips/tricks to getting it away from spring holder? What is best place to buy parts for these? Need piston and all clutch parts. Thanks Matt
450B dozer
There should be a set screw under the bolt you removed, but not always. Stick an allen wrench down in there and see if you find one. If so, back it out a few turns, then the grease will come out.
I must be missing something, once the track is split, the whole idler assembly and adjuster should slide forward I thought. As far as getting the piston out of the barrel, put a grease gun on it and jack it out, far and away the easiest way.
HI and WELCOME if you have not read it look at this thread on 450 same problems you have http://www.jdcrawlers.com/messageboard/ ... sc&start=0
Lavoy I'm trying to get the piston out of the spring end not the front idler/adjuster end. Is this the proper way to reply to a persons response? Is there a way to respond to just their response or like I am doing now? Also what is the best way to add pictures? A picture is worth a thousand words right? Thank you so much Matt
450B dozer
https://mail.google.com/mail/u/0/?ui=2& ... w1312-h511
I sent photo from my phone to my email and copy and pasted it in here. See if this works
The front cross member(behind the pipe wrench) hits the piston when I slide the track frame out. Need to remove piston.
450B dozer
Can't use a photo host using https. Meaning secured. I mean with IMG tags.
A link to an https host is ok, as you posted. Except this one needs an ID and password...
I suspect you need to make the pic public on you host site, and then it won't need an ID and PW.
Users browsing this forum: No registered users and 31 guests
