350C isolator CONVERSION - "C" to "D"
O.k. as many on here know I am converting my "C" isolator into a "D" series isolator to get rid of the rattle and potential reliability issues associated with the spring style. I have the flywheel, rubber isolator, rivets, and the center hub is done all but the splines that a machine shop is making for me(looks very nice I might add). I pulled the reverser out to get the proper endplay on the forward clutch hub and countershaft. also, I am replacing some seals and the coupler from the reverser output to the transmission input with all new parts from Deere. I intend to post some pics of this project as I assemble it. Hope to start putting it all back together come Friday and with a little luck have it done buy the end of the weekend.
Last edited by cantbeatadeere on Mon Feb 23, 2015 7:32 pm, edited 4 times in total.
Heck Norb, I ride atv and sleds up your way all the time, I'm in the Camden area. when I am done this dozer will be as mechanically sound and complete as any you can find. I am using the parts manual and putting every nut, bolt, washer and component back to its' original state....even the "boot" over the tilt ram is new. tin work is almost perfect although the person whom painted it (long ago) did a kind of poor job in my eyes. as my father says "just leave it's work clothes on instead of making it pretty"........ maybe later....
Pre tear down.....https://scontent-b-lga.xx.fbcdn.net/hph ... 3604_o.jpg
Any time you want Norb.............here is a few more pics, including the new flywheel, isolator and pilot bearing. Couple pics of misc. things that are being re-sealed, reverser is going to have the end play on the shafts checked and adj. to spec.
how can I make the pictures bigger???? these small pics kinda stink....O.K got it figured out
https://scontent-a-lga.xx.fbcdn.net/hph ... 6189_o.jpg
Last edited by cantbeatadeere on Thu Dec 25, 2014 6:20 am, edited 5 times in total.
Last edited by cantbeatadeere on Thu Dec 25, 2014 6:16 am, edited 1 time in total.
Last edited by cantbeatadeere on Thu Dec 25, 2014 6:14 am, edited 1 time in total.
Last edited by cantbeatadeere on Thu Dec 25, 2014 6:15 am, edited 1 time in total.
Isolater
Can'tbeat a deere.. Please show more pictures of the Isolater and flywheel. and if you can at a slight sideways angle to see how you fixed the center hub of your Isolater.. I found mine finally and sorry it was all to late for you guys... but I am hoping I can duplicate what you guys have done,, Although I have no clue as to the flywheel differences,,thanks
Oh also that is a very nice looking dozer and great pictures,,thanks..Mark.
Last edited by cantbeatadeere on Sun Dec 28, 2014 3:35 pm, edited 2 times in total.
https://fbcdn-sphotos-b-a.akamaihd.net/ ... 1601_o.jpg
---reverser is back together and in, shimming was waaay off, should be .002-.004 and the countershaft was .014 and the hub shaft was .010 !!! Got them both .002 and .003. new seals as well.
Last edited by cantbeatadeere on Sun Dec 28, 2014 3:39 pm, edited 1 time in total.
https://scontent-a-lga.xx.fbcdn.net/hph ... 0397_o.jpg
---more pics of the flywheel and isolator---
Last edited by cantbeatadeere on Sun Dec 28, 2014 3:41 pm, edited 1 time in total.
Users browsing this forum: No registered users and 33 guests
