hydraulic filter in tank jd 350 loader
butchb
Post by butchb » Sun Dec 14, 2014 5:26 pm
how do i replace hydraulic filter in my 350 loader, filter is in tank?
1967 jd 350
splam
Loader Filter
Post by splam » Sun Dec 14, 2014 7:29 pm
If you are referring to the filter that is located in the tank under the right hand arm rest you simply remove the bolts that hold the filter cover and lift it out. There is a drain plug in the bottom of the tank so you can drain the oil first if you are changing the fluid.
butchb
filter removel
Post by butchb » Mon Dec 15, 2014 4:18 am
took bolts out filter housing will move a little but will not come out, was not sure did not want to tear somethilng up.
1967 jd 350
jsal
hydraulic filter
Post by jsal » Tue Dec 16, 2014 6:33 am
your filter may have split as the case with mine had to pry it up that is the only way to get to it is by removing the cover.
jim
butchb
hydraulic filter
Post by butchb » Tue Dec 16, 2014 7:22 pm
thanks for the reply, have pulled and pryed with crow bar and the cover will not come off.
1967 jd 350
Users browsing this forum: No registered users and 72 guests
