JD straight 450 input shaft
yooper2001
Post by yooper2001 » Sat Oct 18, 2014 8:01 pm
Hello! Thank you for taking the time to read this. My
Dads JD straight 450 had the HLR input shaft shear in
half. The problem I am having is the Parts Catalog states
it is an AT21511, but it is different than shown. On the
front of the shaft it has a spline and a snap ring and a
keyway on the back of the shaft...but all of the shafts I
have found have a keyway on both ends....If anyone has
dealt with this before or knows where I can locate a
serviceable one help would be appreciated.....Thank you.
Post by jtrichard » Sun Oct 19, 2014 9:03 am
can you post a pic of the shaft you have
yooper2001
Post by yooper2001 » Sun Oct 19, 2014 5:10 pm
I hope this works...Image
ja600
Post by ja600 » Mon Oct 20, 2014 7:20 am
That looks just like the one in my 450 also. Can't help with locating parts but I would suggest figuring out why it broke. Are your bellhousing spacers broken? Did the engine mounting bolts break or work loose? Something put a lot of stress on the shaft. Good luck
Machinist by trade, farmer by blood.
yooper2001
Post by yooper2001 » Mon Oct 20, 2014 8:20 am
Yes, three of the four Bell Housing bolts were broken(apparently for years...long before he bought it by the rust on them)....Now drilled and replaced with one inch CAT bolts.
yooper2001
Post by yooper2001 » Mon Oct 20, 2014 9:51 am
OK I finally know why its different.....its the input shaft for a dozer with a power take off.....Now to find one..
yooper2001
Post by yooper2001 » Fri Oct 24, 2014 3:04 pm
Thanks to all....700 dollars lighter...but dozer functional again! Lesson learned.....Inspect the bell housing bolts when buying a 450 dozer....
ja600
Post by ja600 » Tue Oct 28, 2014 12:17 pm
Wow! That was quick!
Users browsing this forum: No registered users and 297 guests
