I would like a experienced mechanic familiar with the JD450B to perform service, and show me what I should be doing, at my property in SW NH.
I will be attempting to adjust the steering clutches but know knowledge has value.
I also noticed a weeping hydraulic hard line on the loader and while I have changed many soft lines, suspect this may be a bit daunting to me.
JD 450B mechanic desired near SW NH
srshaw3
- Contact:
"It is incumbent on every generation to pay its own debts as it goes."
Thomas Jefferson
Thomas Jefferson
Labparamour
Not sure I copied it correctly but, here is thread I started (on page 2 of late model forum) when I changed out some lines:
http://www.jdcrawlers.com/messageboard/ ... php?t=9116
If you've been tearing in to your machine already it sounds like you're plenty capable.
It's a challenge working in cramped quarters but, with a little finesse and some strong-arming, the hard lines can be done...it may just be a loose fitting.
If you have the manual then adjusting steering clutches is pretty easy but, as others have mentioned in posts, there is a sequence to follow.
I made copies of the pages and had them beside me while doing it.
Good luck,
DB
Good luck,
DB
srshaw3
- Contact:
Thanks for the reply, I am just concerned I make a wrong adjustment and wear out the clutch or the brake. I do have the manual in a pdf and bring it with my, on a notebook, but the directions are not as clear as I would like.
Ironically I am considering trying to pick up another 450B, in dozer form. I do like the simplicity of the machines.
Seems like for lot clearing many prefer the loader, but I expect for the grading aspect the blade would be better.
Of course I wouldn't mind an excavator either
Do they exist in comparably functional and cost effective form as the JD 450Bs?
Thomas Jefferson
Thomas Jefferson
