Battery CCA for 350B
Just wondering if anyone has a recommendation for battery cold cranking amps for a350B up here in the Great White North? Seems to me the specs for batteries in the Tech manual are kind of low. Would there be any electrical issues using a higher rated CCA batteries?
350 BB Crawler Loader
Have a Great Day!!
Have a Great Day!!
I'd put as big a battery as you could find / fit. Increased CCA has no issues on the electrical system. I'm currently running 1000CCA and I'm thinking about adding a second one for winter starting. I don't normally need it but I'm thinking about doing small jobs for people and I'll need it available all year if I do that.
JD- 450C track loader
Serial #208336T
Serial #208336T
You definitely want a Group 31 battery (those are typically around 1000 CCA), especially if a diesel engine as it takes some effort to start in colder weather. Adding a second is helpful if you have the room, but make sure you attach them in parallel and not in series.
Users browsing this forum: No registered users and 244 guests
