Is there a drain plug on the engine drive clutch bell housing? If so does anyone know what size tool it takes to remove it.
Drain plug on 450 clutch bellhousing
I ran the loader for a while yesterday and ran into a problem. It has been raining heavily for a couple of days. Once when starting the loader, my wife noticed that a bunch of rusty water squirted out of one of the holes in the starter body. Kept working for a while and then noticed milky water and oil squirting out of starter when starting. As I was finishing what I was doing started noticing milky white oil and water trails wherever I went.
My guess is weep hole was plugged and housing had a bunch of water in it. When I started running machine I have a oil leak in trans pump which filled it up even more and finally cleared weep hole out so it started draining slowly.
Is the weep hole the only drain or is there a drain plug also that I can pull out? I don't see any reference to either the weep hole or drain plug in manuals.
