350B rear crossbar
vlyberg
350B rear crossbar
Post by vlyberg » Tue Dec 31, 2013 2:11 pm
I have got the bolts in the front crossbar fixed and now need to repair or replace the rear crossbar. I have read several places where people have welded up the rear bar by sliding it to one side, building up the wear spot than sliding it the other way and doing the same. I have removed the end retainers and the rear bar caps but the step in the bar catches on the rear bracket and wont move beyond there. tried jacking up one side, than both sides etc no luck. Could sure use some help.
vlyberg
350B rear crossbar
Post by vlyberg » Wed Jan 01, 2014 12:17 pm
I got it out, because of the step in the rear crossbar i had to drop the track and remove the track frame to get the bar out. Not to bad a job, it took 2 1/2 hours to remove the right side and slide the bar out.
Users browsing this forum: Google [Bot] and 327 guests
