stering clutches
WMc
Post by WMc » Tue Jul 31, 2012 5:58 pm
Where you able to find all the parts for your crawler..?
I'm running into trouble with USDiesel for my injector pump rebuild...They want the numbers off the pump it self...I can't read the numbers on the tag...Ahw!!!
Walt McDonald
1981 350C JD crawler/1939 Ford 9N
LeonardL
Post by LeonardL » Wed Aug 01, 2012 6:20 am
Walt, Do you have your machines serial number? If you do, you should be able to go to a Deere dealer and have them look to see what pump was being installed at the time of manufacture. They should be able to get you close enough to get a kit or to have the pump rebuilt.
Also, what machine do you have?
rcs110
Post by rcs110 » Sat Aug 25, 2012 8:12 pm
getting it all back together this week !! :D :D
will be posting more pictures next week of it going back together and I hope driving it again!!
thank again Lavoy for the all the parts.
1969 350 crawler
t4e3d
WMc
Post by WMc » Thu Aug 30, 2012 8:27 pm
I'm really glad to see you putting it back together....Cool!
Its cool to see a 43 year crawler come back to life.....!!!!
Great work...I'm learning more and more.
Keep the PICs coming...
Walt McDonald
Post by Lavoy » Thu Aug 30, 2012 10:02 pm
No problem.
rcs110
Post by rcs110 » Fri Aug 31, 2012 7:09 pm
Image well 3 hours and got the drive back on 350 took hope it works . Still have a lot of work to do hope to start it up and test drive it sat
1969 350 crawler
t4e3d
rcs110
Post by rcs110 » Sat Sep 01, 2012 6:50 pm
Image well with help got it all back together . Steering works great. Only thing was I filled the transmission with oil as per the manual 9 qts and it was coming out the fill tune while I was running it.???? I think it has stopped but will find out Sunday when I use it clearing some land.
1969 350 crawler
t4e3d
rcs110
Post by rcs110 » Sat Sep 01, 2012 6:57 pm
1969 350 crawler
t4e3d
rcs110
Post by rcs110 » Sat Sep 01, 2012 6:59 pm
1969 350 crawler
t4e3d
WMc
Post by WMc » Sun Sep 02, 2012 1:45 pm
Great work rcs110
Your great,great grand kids will appreciate that bottle of nickel never seize.....LOL!!!!!
I've learned allot from your posts, The pics are priceless.
Thanks for sharing......
Walt McDonald
rcs110
Post by rcs110 » Mon Sep 03, 2012 7:35 pm
well it still is leaking oil out of the fill tube after running it for 3 hrs steering works great, read the book on how much oil to fill trans, the book said 9qts has any one a problem with this?? i used 303 oil as per the book or should i have used sae 80 gear oil that was also in the book? bob
1969 350 crawler
t4e3d
Post by jtrichard » Mon Sep 03, 2012 8:32 pm
JD uses nothing but 303 in everything except the engine in 350 and newer i was at a JD dealer and could not even buy gear oil 80 or 140
Duke350B
Very nice pic's
Post by Duke350B » Mon Jul 22, 2013 7:47 pm
rcs110 wrote:Image
Thanks,
Duke 350B
andregrondin
Post by andregrondin » Fri Aug 02, 2013 8:26 am
very good job you must be happy !
Duke where are you from ? I see Québec, QC , I'm in Granby
Dig in boy !!
J-D 350 straight 1966
model # = T4F3D
serial # = 08883T
J-D 690-B 1980
model # = D690B
serial # = 007364T
Mack RB688S 1990 dumper
