JD 450B loose track
srshaw3
JD 450B loose track
Post by srshaw3 » Mon Jul 01, 2013 11:30 am
I had my steering clutches done last year, and have been getting some quality seat time on the 450B (clearing stumps and boulders from a clearing). On Saturday I noticed one track had developed quite a bit of slack. I added grease and it looked about right. On Sunday after some more work, it had even more slack in it. I added grease and it tightened up a bit, but then the grease was coming out of the zerk, and the track was not as tight as before.
Thoughts?
"It is incumbent on every generation to pay its own debts as it goes."
Thomas Jefferson
rockslayer16
Post by rockslayer16 » Mon Jul 01, 2013 2:11 pm
losing grease will cause slack, put a new zerk in and see if that fixes the problem.
srshaw3
Post by srshaw3 » Mon Jul 01, 2013 4:55 pm
rockslayer16 wrote:losing grease will cause slack, put a new zerk in and see if that fixes the problem.
Ok, I read in the manual about checking for breakage too, so will review. The zerk does look relatively new.
Thomas Jefferson
