Fan belt replacement.
Nigel
Post by Nigel » Tue May 28, 2013 4:51 am
Can anyone help me with info on the best way to change the fan belt on a 350B Drott?
It looks like I have to take the hydraulic pump off and separate the shaft.
If there is an easier/correct way I would like to know!
rockslayer16
Post by rockslayer16 » Sun Jun 02, 2013 3:22 pm
yes you have to remove the shaft, buy two belts and zip tie one behind the shaft so next time you need to change it you do not have to remove the shaft, and the belt is right there waiting. this is how mine is setup, the previous owner had done it and its a great idea.
Nigel
Post by Nigel » Sun Jun 02, 2013 8:25 pm
Thanks for the tip. I will be doing that for sure!
Users browsing this forum: No registered users and 392 guests
