final drive housing 350B
gene s
Post by gene s » Sat Sep 01, 2012 6:36 am
is it ok to switch final drives from one side to the other? Reason for this question is that I found 3 stripped 3/4 inch bolts that attach rear crossbar to the housing on left side. According to my parts book both sides are same. If I can switch sides it would give the unstriped holes where I need them, and since I have to remove the left to repair, maybe I can remove the right side and put it to the left, and then left side to right. Does this make any sense??
MF40, MF30,350B
LeonardL
Post by LeonardL » Sun Sep 02, 2012 11:32 am
Yes you can switch sides with the finals.
Users browsing this forum: No registered users and 144 guests
