stering clutches
stering clutches
while working my dozer started smelling something. steering clutches had strong amonia odor and right side quit pulling. parked it for a few hours went back and tried it pulled forward and back with left side locked but didnt put under load.did i ruin the new clutches or is there hope.also i believe the right track was to tight,working in gumbo and might have been problem.when i took plate off under seat very hot in housing.
1966 350 straight gas
1930's GAR WOOD scraper dirt pan
Brake band too tight? I had similar problem with my 350 straight, too tight brake band was problem. New bands are hard to get adjusted right untll they get "seated"( I guess would be the word for it)
57 420c 86 Ford 4600
67 350 dozer
66 350 loader
58 Oliver OC-4
48 8n Ford
49 Farmall Cub
Struck Mini-Dozer
67 350 dozer
66 350 loader
58 Oliver OC-4
48 8n Ford
49 Farmall Cub
Struck Mini-Dozer
The first thing I thought when I saw "strong smell of amonia" the very first thing that came to my mind was mouse piss. I carry a fire extinguisher in the tractor at work for the inevitable electrical fire that will happen in the overhead counsol due to mouse piss. On these 80 degree days I wish it was open station. Guess one of these days I will have to pull it all down to rewire the whole mess.
I am sure CDunn is correct on the brake band. If it moved correctly when it had cooled down
steering clutches
so what you are saying is the brake band was seizing up even though it would still roll forward with no levers pulled back while it was hot?can to tight of a track cause any problems like that,i didnt lossen them up going into the gumbo.
