JD. 350b final drive
tdk
Post by tdk » Sun May 13, 2012 5:55 pm
I'am having a problem with a final drive on a JD.350b.I took it apart and everything looks good ,no oil or anything bad.I was told the thickness of the steel spacers should be .090 to .096 mine are all around .093 Does anyone know what the metalic discs should be. Mine measure about .175 are these ok to re use.Thank you Tom.
andregrondin
Post by andregrondin » Mon May 14, 2012 6:43 am
Hi !
I do not know the specs on 350B for disk , but are you sure all is good ??
check the pressure plate to find if all the clutch fingers are working properly ,
Is the thowout bearing still turning properly ??
Is the clutch fork actuator is working free ??
is the disk all rusted ans pitted ?
is the fiber disk still nice ( I had two broken ) ?
hop this hlep
Dig in boy !!
J-D 350 straight 1966
model # = T4F3D
serial # = 08883T
J-D 690-B 1980
model # = D690B
serial # = 007364T
Mack RB688S 1990 dumper
Users browsing this forum: No registered users and 393 guests
