450D seat frame
- ridgerambler
450D seat frame
I need the seat frame for my 450D. It is JD part #AT49463 and I think it is the same as the 450C, at least the later models. The entire thing was missing when I got the machine. Anybody out there have one they can part with? I can be reached at ridgerambler@hotmail.com and I can provide a phone # is somebody has one. Thanks!! Tom
I think those 450D frames are the same seat frames that are on a 350C. Maybe even the older 350s. I know that later 350Ds had a different seat. Have you tried to find a salvage dealer in your area? They would be your best bet for this.
- ridgerambler
450D seat frame
I have tried local salvage dealers and have also tried those in PA and TX that have web sites--no luck so far. I think the frame may be the same on 350-350C; 450-450D; 455D; 550; 555 and 555A--at least the same seat cushions fit those models according to my local dealer. I was in hopes that someone on the forum may have an old frame they no longer use. If I cannot find one, I can make one, but would rather find a salvage one if possible.
Sense you are willing to go out state with your search... Try Zimmerman Tractor in Versailles MO. ( 573 - 378 - 7210 ) If they don't have it they may be able to give you another place to look. I know they ship all over the U.S. and are great to work with. They are Amish Minanites and don't exactly carry on with great conversation, ( Blunt and to the point ) but they are great people to work with. I have used them several times over the years.
You might also give these guys on here a little more time as there may be someone who hasn't seen your post yet. Good Luck!
you can also try DON PEILA TRACTOR in OR. 877 423 9746 or 541 772 1801 kinda far but he should have what you need...... also very nice to work with and he is very knowledgeable on JD that's all he has is JD parts and will help with any questions you have on your JD
Correct me if I'm wrong here, but I think partway through the 350C run the seat frame changed. Early machines you had to remove some bolts in the angles under the frame to change position. The later machines use a seat with adjustable rails and a lever under the cushion. The part number you list fits the early 350Cs (not sure how 450s are set up). I picked one of these up a while back at Wengers of Myerstown in PA (1-800-552-5080) . Not sure if they have another one available but it was only around $100.
