Deere used ether atomizers mounted inside the air-intake manifold to help prevent that lag and overloading. We didn't let any 350s leave the shop without them. But after time the plastic ether-line would break and many owners sprayed raw either into the air cleaner anyway. When an operator is alone and the ether injector is not working (or usedJ) it's sometimes impossible for one person to spray when cranking.Lavoy wrote: When I ether anything, if you push the botton on the can for more than one or two spurts, it is way too much With the tractors and combines that have factory installed electric actuated ether injectors, we never ethered until the engine is turning over, and then press the button for half a second or so.
