JD backhoe attachment
bamaboy2006
Post by bamaboy2006 » Mon Dec 05, 2011 6:53 pm
Does any know what a backhoe attachment for my JD 450b would run? Also do you have any idea where I could get one?
KenP
Post by KenP » Mon Dec 05, 2011 8:11 pm
deleted
bamaboy2006
Post by bamaboy2006 » Mon Dec 05, 2011 9:14 pm
I am not sure if it has the hoses or not. It does have some kind of bracket but not sure if it is all there. I know it has two extra levers on the right side that I assume have something to do with a backhoe.
Were would the hoses be? Under the seat?
JWB Contracting
Backhoe Mouting
Post by JWB Contracting » Mon Dec 05, 2011 10:16 pm
Do you have a loader or a dozer machine?
The plumbing for a hoe is really not that complicated. Why don't you take a picture of the valve area from the top and from the trap door on the side of hydrualic tank.
Hoe hooks are getting very hard to find in my option. Hoes are not that difficult, although I have been looking for a 9550 in any condition for some time. 9300's and other models are much more common.
We have also adapted other hoe attachments to fit the deere mounting brackes, such as a hoe off a 580 case loader backhoe, Case D125 Hoe off a trencher and a mid sized Ditch Witch hoe.
Think about what type of hoe work you are going to do. If you want to dig in 8' deep water lines go with a full size deere hoes. If you need something for shallow work, consider doing a conversion on another brand of smaller hoe. Depends if you have the time and tools.
Jason Benesch
John Deere 400G With Winch
John Deere 2010 Crawler Dozer
mot
Post by mot » Tue Dec 06, 2011 12:07 am
there is one on ebay right now and I saw one on CL couple of days ago but cannot find now. but no mounting brackets showing with either
JD450b, Drott 4-way bucket, 9300 backhoe: Ford 9N: Owatonna 1700
KenP
Post by KenP » Tue Dec 06, 2011 4:20 am
deleted
bamaboy2006
Post by bamaboy2006 » Tue Dec 06, 2011 8:15 am
My loader looks just like this one except there is not a hose hanging down.
I took a couple of pictures but can't figure out how to post yet.
bamaboy2006
Post by bamaboy2006 » Tue Dec 06, 2011 2:51 pm
Rear Bracket on my loader
bamaboy2006
Post by bamaboy2006 » Tue Dec 06, 2011 2:52 pm
Extra Levers on Right side
bamaboy2006
Post by bamaboy2006 » Tue Dec 06, 2011 2:53 pm
Hydro Valve under right side compartment
gerald
Post by gerald » Wed Dec 07, 2011 10:43 am
I have 93 A back hoe it,s a burte. I ran it last week to brake up clay. The out riggers leak off. The bushing are worn out it swings very good an digs good . Its way to big for my 1970 350 thats what Deere put on them. Its alot better suted for the 450. I have a smaller 1500 LB case hoe that looks an works fine for my 350.I think my 93 A should be worth 1500$
bamaboy2006
Post by bamaboy2006 » Wed Dec 07, 2011 12:45 pm
Were are you located and would you be interested in selling the 93 model?
LeonardL
Post by LeonardL » Wed Dec 07, 2011 1:36 pm
Hello,
I was looking at the pictures you have and I notice in one picture there is a hydraulic line that could very well be one of the lines you are looking for. If you could get us a good clear picture of the area directly under the seat cushion, that would be great. I'm wondering if the backhoe lines are under your seat as apposed to hanging down where they usually are?
On another note, I noticed you have been using concrete blocks to use as blocking... I'm not trying to be a smart ass but you really don't want to use concrete blocks. From what I see in one of your pictures, you have already had at least one fail. Get you some good tie blocks or some sort of good square cut, hard wood blocking. Don't use fire wood! Get them large enough to be stable and if you can get it on firm ground that would be even better. I personally would like to see you around this forum for a good long time and not have to be reading an obituary. Please be careful when jacking these machines up off the ground. Being safe is always better than being sorry. :)
Again I'm just concerned for your safety. Leonard
bamaboy2006
Post by bamaboy2006 » Wed Dec 07, 2011 3:16 pm
Thanks for your concern. I just had in sitting on those for a temp fix. I am planning to put it on cross ties when I get ready to put the track back on. I think I have another picture of that compartment. I will post asap.
bamaboy2006
Post by bamaboy2006 » Wed Dec 07, 2011 3:24 pm
