550 Engine Pull Question
Just bought my first power shift dozer, 1977 550. Engine is drinking antifreeze, the head was checked by previous owner with new head gasket installed and problem persisted, I am assuming it is a liner. With that said I am going to pull the motor. I have a repair manual coming next week but I was hoping to pull the engine tomorrow. My question is: Does the torque converter unbolt like a car converter or is it different? If it is like a car is there access to get at the bolts? Thanks.
Two things here is the antifreeze showing up in the motor oil ?If it is then you have a liner issue if not figure where the antifreeze is going to before removing the motor .Get back to us on your findings .Number two leave the converter attached to the ring gear and lube the pump drive with Vaseline when it comes time to put the old Deere back together.Digitup .
Users browsing this forum: No registered users and 303 guests
