My only thought is if it was if he was able to run it that long with good oil, the bearings can't be too far gone, and he might have a shot at it.
350 diesel shutting down
well the front rod bearing spun and looks as if I will be needing a new crank or get it turned. I think I am going to start changing undercariage parts to the gas unit. The only tough part is I need to change the front crossbar and it appears the loader is resting on it. Thanks everybody for the help Now I got to get both machines blocked up and start swapping
Users browsing this forum: Bing [Bot] and 248 guests
