450C Spool Valve 6 Way
Farmboy
Post by Farmboy » Thu May 05, 2011 5:46 am
Hello All,
It is difficult to find down pressure and my float detent doesn't engage. It has been this way since I got the machine - not getting worse. Otherwise hydraulics seem good - no leaking off.
I have the machine inside going over hoses, etc. and would like to fix this.
Can anyone give me any tips on where to look / start and what I might be into?
Many thanks!
Bill
450C
gerald
Post by gerald » Thu May 05, 2011 6:07 am
Inside that valve there are ports when you move the lever the spool lines up with the port your useing . My guess would be to look at the hyd schemtic an find a check valve first then go into the valve to see if there isn't something lodged in that port
or even galled spool in that one area,
gerald
Post by gerald » Thu May 05, 2011 6:08 am
FL450B
float the blade
Post by FL450B » Thu May 05, 2011 9:49 pm
my 450 b would not get to float my linkage had a lot of play i pull it apart and repaced pin and i had to make some bushings but now down pressure is easy and it locks in to float
Farmboy
Post by Farmboy » Fri May 06, 2011 5:45 am
Sounds like it could be linkage or inside.
I bought a bunch of plugs and I'm replacing hoses so I'll get it out and go from there. I do have considerable play in the linkage but it didn't seem that bad. I checked on a linkage kit and it was $900 so I know I won't be going that route.
Thanks.
Bill
450C
JWB Contracting
Quick Linkage Fix
Post by JWB Contracting » Fri May 06, 2011 1:23 pm
I have seen a few machines with poor linkage that were fixed with a cutting torch or a grinder. Simple cut away part of the guard surounding the T handle so that you can move the lever farther. If you are not worried about restoring your crawler you could go this route.
Jason Benesch
John Deere 400G With Winch
John Deere 2010 Crawler Dozer
Willyr
Post by Willyr » Fri May 06, 2011 1:38 pm
Chances are if you are using the lever kind of valving you need new orings on your valves.
However. If you have a joystick where it is cables running out to a seperate valve body.... I would recomend you first check adjustments and your cables.
former owner of a 1956 420c
Farmboy
Post by Farmboy » Sat May 07, 2011 6:04 am
I don't know but was told by the dealer that the o-rings don't have any affect on valve function - just there to keep from leaking. Getting it out doesn't look all that difficult since I'm replacing hoses anyhow, so I'll get it out and take a closer look.
Thanks for the replies and I'll report back.
Bill
450C
teighs
Post by teighs » Sat May 07, 2011 7:27 am
I had a 2010 with real sloppy linkages on the 6-way. I took the valve into the shop, drilled out each hole in the linkage to the appropriate size and put in the next larger roll pin. Tightened it up like new.
On my current 350 the lever wouldn't hold in the float detent. There is a linkage outside the valve body. Make sure it's clean and not worn out, mine was worn out, bought the new parts at jdparts.deere.com
FL450B
6 way
Post by FL450B » Sun May 08, 2011 8:36 pm
for 5 years i ran my 450 with the cover open but with 10 dollars for pins and some steel brake lins to make some bushing it work great pain taking off the vavle but you can tear off with some time about 2 hrs it will work the way it should note on the machine no hyd lines removed
Farmboy
Post by Farmboy » Mon May 16, 2011 8:20 pm
I got the spool valve off and took off the cap and detent at the bottom of the lift circuit spool. It was a corroded mess. I think I have how it is supposed to work figured out. The plunger looks like it has no lip at all left. New parts should be here in a couple days. Will try to post some pictures before putting it back together.
450C
Farmboy
Post by Farmboy » Thu May 19, 2011 9:42 pm
Some photos:
450C
Farmboy
Schematic is WRONG
Post by Farmboy » Fri May 20, 2011 2:08 pm
Just for what it's worth to anyone who might go through this process, the JD schematic for this Spool Valve is WRONG!
Part number 22 (Plunger) is shown backward.
There is no way it will go together as shown.
Also the 5/16" lock washer (27) they send you will not fit on the screw. It is a no go.
450C
tjdub
Re: Schematic is WRONG
Post by tjdub » Fri May 20, 2011 11:23 pm
Farmboy wrote: Part number 22 (Plunger) is shown backward.
Thanks for the tip. My 450 has the same symptoms with down-pressure and I will probably be doing the same thing if I ever find time and money. The schematic goof is pretty funny. Too bad the guy who drew that has probably been retired for a while now or you could call Deere and get him in trouble :)
lp14255
Post by lp14255 » Sat Jun 11, 2011 8:28 pm
hello farmboy i'm in the process of rebuiding my 350 crawler. the control valve on it leaks bad , what where the part numbers on the o-rings and everything you used to rebuild yours.
1969 jd350 crawler dozer
Users browsing this forum: No registered users and 117 guests
