I'm looking for the tube that screws into the engine block, on my 66 450, the original broke off, I was able to ez out the broken portion, but I'm missing approx. 1/2". so I probably won't get an accurate read on the oil level, the original is about 4.5" long. Also I have some minor oil leakage coming fro the flywheel on the front of the engine, does anyone know if that has a gasket that can be replaced or is that more indicative of a bigger problem?
oil dipstick tube
oil dipstick tube
1966 JD 450 Crawler, 1986 Case Super E Backhoe, 2001 Kubota 7800, 1986 GMC 1 ton dump truck,1991 GMC Topkick dump truck
I had to buy a new dipstick, along with tube, as the new tube won't accept the old dipstick, it seems as if the original one is no longer available. I bought a used tube from PB&H in Antrim NH (They're a great place for older deere parts) and a new dipstick at Nortrax. Know all I have to do is fix the leak in the crank.
Users browsing this forum: No registered users and 265 guests
