pictures if you do it Ken. I think the alternator on my 350 is on the way out so i would go this route also.KenP wrote:Thanks for the update. If this works out, I'll probably give this swap a try on my 350.
Don't know much about GM Delco stuff but wondering if GM trucks might have a heavier v-belt and so a wider pulley.
If there's a local alternator rebuild place, you could give them a call and ask. They're probably know the answer right off the top of their head.
Delco one-wire alternator conversion
1970 350 with a 93A backhoe attachment
I don't recall seeing it, but have you tried using a link belt instead of a rubber one? The link belts and great as they can be made different sizes and adjusted as needed - remove or add links.
marina
marina
Hixon, BC, Canada
1968 JD450 Crawler Loader with ROPS, outside blade,rock guards, bucket and winch.
I'm definitely thinking about it. I did a search on here for how to get the fan belt off and I saw them mentioned. It looks like I'll have to pull the hydraulic pump to change the belt out with a normal one? My 450 has the hydraulic pump disconnect thing on it, but unless I'm missing something, there's no way to slip a belt past that without taking the hyd pump out first.Mariner wrote:I don't recall seeing it, but have you tried using a link belt instead of a rubber one? The link belts and great as they can be made different sizes and adjusted as needed - remove or add links.
If I go with the link belts, does anyone have opinions on brands or where to buy?
Users browsing this forum: Google [Bot] and 10 guests
